When I click on to a Sky movies channel, it often asks for my pin number, & it's a pain to enter it every time!! Isn't there any way in which I can configure the "E" or the "+" button to enter the pin number automatically?
You can then name the Sequence as ENTER PIN and then set up to 5 commands (1 for each PIN number) all using Sky Box as the Device and then hopefully your PIN code as the Command settings
Should work but have never tried as I do not have Sky Movies.
Yup I don't have Sky but I do that for Virgin V+ anything recorded after 21.00 watershed. If you have probs post backand let me know , just going out so can't give exact sequence just now but above looks good.
