This thread has the potential to deteriorate, so please keep it civil and stay on topic....I really don't want to get into any specific, contentious issues
What I want to do is dig behind all the posturing (on both sides) and get to the heart of one simple area ie. what do you rely on when buying a system.....and I don't care what the system is.
The scale goes like this:
1. If it measures right, I will buy it unseen/heard.
2. I will always listen, but wouldn't buy it, if it didn't measure well.
3. I buy on what I hear, but make sure that I've also checked the specs/measurements, to avoid disaster.
4 I don't care how it measures, I will buy it if I like it.
As far as I'm concerned there isn't a right answer; but I suspect Subjectivists check measurements and Objectivists also listen (even if they take different paths). I also suspect there is more common ground than there often appears.....and as blokes and audiophiles, we just like a good argument.
So please forgive what may appear to be old ground...but it's old ground with a specific twist.
