You called? :rofl:
I have only had the two 'T-Amps' which both were based on the Tripath TA2020 chip. The previous was an Amptastic model, and my current one is a Muse M20. They both have the standard PSU.
The TA2020 is around 8wpc/8ohms (0.1% THD Distortion) and goes up very quickly to around 1% at ~10wpc output and 10% at ~13wpc output. So they really are best kept in their comfort zone.
I think there is a lot of hype regarding 'T-Amps'. I really like them but you have to take in to account the price. They are Brilliant for a new amplifier ~£50, and thats it really. They are cheap, mine is used as a backup amplifier, they are so small and run cool I really cant find anything to fault about them other than some have a stupid bright LED for some reason.
I have read good things about the larger ones, which are supposed to be very different beasts like the Topping TP60 TA2022 based ones for example.
I would avoid any chinese import ones generally and only buy from a proper UK source. The Amptastic and Temple Audio Bantam Classic (TA2024 based IIRC) are both Tripath based and UK built.
I used the Amptastic TA2020 well with a variety of speakers, two being the 80dB ATC SCM10 and Keesonic Kolt in a small room, and for a study/bedroom system with more 'normal' it would be hard to beat unless you needed high volumes. That particular T-Amp sounded better in my little room at the time than my other favourite amp, the Sony 770ES (although for anything other than low/medium volumes, there was no contest) and a few others including the Rega Brio3, Sony TA-FA448E, Arcam AVR200 and the Temple Audio Bantam Gold (similar but not a Tripath based amp). In that room, I ended up with a Sony TA-F670ES mainly as it has a cracking phonostage.
So thats it really, they are so cheap you can just get one and see how you get on, dont expect the world and you may well be supprised.
