- Aug 10, 2019
- 2,556
- 4
- 0
Hi AudioAsylum, I am new to the forum and would like some advice regarding a tube amp setup in my apartment.This is what I am thinking about for the setup...22 tu:tu tube ampVacuum tube: 6SN7GT×2pcsMaximum output: 12W+12W (when 6~8ohm speakers are used)Frequency response: 15~30000HzDimensions: W265×H103×D151mm (including projections)A project audio RPM 5.1 turntable and two B&W CM1 or CM5 speakers.I just wanted to ask about the watt output from the tube amp compared to the specifications for the speakers.The speakers ask for a recommended amplifier power of 30W - 100W into 8ohm on unclipped programme.So I have two questions...Does this mean that the 22 tube amp is not powerful enough for the speakers?Would this setup be suitable for a small 70m2 apartment?Hi WhatHifi,I am new to the forum and would like some advice regarding a tube amp setup in my apartment.This is what I am thinking about for the setup...1 x 22 tu:tu tube ampVacuum tube: 6SN7GT×2pcsMaximum output: 12W+12W (when 6~8ohm speakers are used)Frequency response: 15~30000HzDimensions: W265×H103×D151mm (including projections)1 x project audio RPM 5.1 turntable and 2x B&W CM1 or CM5 speakers.I just wanted to ask about the watt output from the tube amp compared to the specifications for the speakers.The speakers ask for a recommended amplifier power of 30W - 100W into 8ohm on unclipped programme.So I have two questions...Does this mean that the 22 tube amp is not powerful enough for the speakers?Would this setup be suitable for a small 70m2 apartment?
Hi WhatHiFi, I am new to the forum and would like some advice regarding a tube amp setup in my apartment.This is what I am thinking about for the setup...
22 tu:tu tube amp
2 x B&W CM1 or CM5 speakers
Thanks!
22 tu:tu tube amp
Thanks!
