- Aug 10, 2019
- 2,556
- 5
- 0
Hi
My current home cinema set up consists of a Pioneer 436XDE plasma panel, a Yamaha RX-V4600 7.1 amplifier and B&W 7xM1 speakers and 2x B&W PV1 subs. I am currently using the amplifier to switch two HDMI sources through to the plasma panel.
Last week I bought a JVC HD100 projector and have a couple of questions regarding getting the best picture and signal quality with my existing equipment.
I am aware that the Yamaha RX-V4600 is only HDMI 1.1 and can only output 1080i even if it is passed a 1080p signal) and that the projector has a built-in scaler chip that can deinterlace a 1080i signal and display it 1080p.
Q: Is the Yamaha amplifier the weakest part of my home cinema setup? Is using it in the configuration above going to reduce the resolution/quality of the signal due to the number of conversions? Should I try to preserve the original signal from the PS3 directly to the projector?
I have been considering the following upgrade paths:
1) Purchasing an Onkyo receiver that allows 1080p switching as well as decoding the new DD/DTS HD Master audio formats.
2) Keeping the Yamaha and investing in a HDMI amplifier to split the source signal into two - one to the projector and the other to the amplifier. Could anyone recommend such a device which is HDMI 1.3 compliant?
Sorry for the long post, but am I not sure whether this is anything to worry about...
Many thanks in advance
Mark
Mark
