- Aug 10, 2019
- 2,556
- 5
- 0
Hi
We are looking at replacing my age old pathetic hifi and decided that our best bet, given that we watch a lot of flims and music, would be to get a home cinema system that would also be good enough for our limited music needs.
We have been looking at the Sony DAV-IS 10 after reading the reviews in What Hifi and seeing the ridiculously small size of the speakers - as my other half does not like the idea of anything too obtrusive.
On visiting the Sony shop (to look not buy) it became apparent that to get anything out of this we would need to replace our 6 year old widescreen TV - as all the connectors have changed from those days!
We looked at a few options and the Samsung LE32R87BDX 32 Inch seemed like a good "cost effective" bet again given the WhatHifi rating. We have found a deal for this TV plus the DAV-IS10 for £880.
Given my ignorance, I was interested in whether anyone was able to say whether this was a good option, suggest any alternatives and also advise as to what cables/connectors we would also have to buy - the last time I was in the market for such equipment they came as part of the deal - but apparently this is no longer the case - and the Sony guy was saying we would need an £80 cable.
We would be connecting the above systems to a Sky+ box - not HD at this stage, but may consider this moving forwards if I can sneak through the upgrade with the wife! Our lounge is 5.69m x 3.3m with wooden flooring if that helps!
Many thanks for any advice you can offer someone who has no idea about this sort of stuff!
http://www.directtvs.co.uk/Samsung_32_inch_HD_Ready_LCD_TV_LE32R87BDX/version.asp http://www.directtvs.co.uk/asp/basket.asp?R=6500&V=remove http://www.directtvs.co.uk/Sony_5.1_Home_Cinema_System_DAV-IS10_DAV-IS10/version.asp
