Home-Cinema Speakers - Large or Small?!
Big Aura
522
10
18,895
Happy new year to you all.
I re-calibrated my system over the weekend, using the Denon Audessey thingy and notice that it has decided that my speakers are "small". I read once (probably on here) that you're better to always have your speakers set to "large" unless they're really tiny; my system details are below - I would imagine they're closer to "medium"!.
Does it matter how the amp recognises speakers - i.e. what it is the practical difference between large and small, and secondly - will it throw the calibration all out of sync if I manually re-set them to large?
__________________________________________________________
Sony LCD (KDL40W4500), Denon AVR-1909, Sony RDR-HXD870, Humax Foxsat, B&W 685s, B&W 686s, B&W HTM62, Jamo E4 sub, Nintendo Wii, QED Performance HDMI-HDMI, QED Silver Anniversary XT speaker cable.
Big Aura
522
10
18,895
Thanks - does it make a difference whether the amp thinks they are large or small? And does changing manually impact the audessey auto-calibration?
Gerrardasnails
295
Big Aura:
If you want the amp to control your subwoofer, you will need to make your speakers small. I have mine set to small, I don't think it makes any difference to the sound and my receiver controls when my sub kicks in.
professorhat
992
22
18,895
True. If you change them to Large, you'll need to tinker with the sub's crossover frequency and probably best to check the level as well.
Big Aura
522
10
18,895
Thanks - this is starting to get a bit techy! Will have a bit of a play around tonight. I guess I don't really care if the amp controls the sub levels, but I only use the fronts (without sub) for music in the "pure" setting, so will need to ensure that they auto-select as "large" for those purposes.
