hi i'm looking for advice on the best installation options.
Im wall mounting my 42" plasma above an open fireplace - although the chimney is operational we wont use it. Walls are brick. To the left as you look at the chimney is a bookcase and low cupboard which will house the subwoofer, receiver and components (dvd, apple tv & wii).
What do you suggest the best options for cabling. Ideally i would like to hide this in wall. In practive I guess this means drilling a route through the brick to behind the tv mount. Is this feasible? The fireplace is flush to the wall so would look unsightly to surface mount cables around it
Also, if this works should I look to feed all my connections directly through to the tv (2 hdmi, 2 scart + future proofing) or feed 1 hdmi cable from tv to a switcher in my cupboard. I can always replace the switcher later as scarts are replaced by hdmi.
