Andrew Everard:And of course the cable linked to is designed for interconnect duties, even for up to 64 channels, and not speakers
Thanks Andrew, Link Corrected.
To the OP, I thought you only wanted a 1m length? If it is to hide under the carpet, I would look at the Ixos 233 flat or if it is being run around the room, consider the Van Damme Hifi cable. Most cable will stick out when run under the carpet but I've used the Ixos stuff for a few years and it doesn't show up as much.
