- Aug 10, 2019
- 2,556
- 5
- 0
I was wondering if anyone with far greater experience than I would be able to offer some advice regarding my planned home cinema setup?
In the next month or so i plan on buying the following equipment:
- Panasonic TH37PX70 Plasma TV and wall bracket (£680.00)
- Onkyo TX-SR605 AV Receiver (£400.00)
- Samsung HD870 DVD Player (£47.00)
- Q Acoustics 1010 5.1 Speaker System (£450.00)
- Q Acoustics 1000ST Speaker Stands x 2 (£140.00)
- SKY+ Box (£100.00)
The plan is to have the TV mounted on a dry lined redundant chimney brest with the other components located within the redundant fireplace and all cables run through the wall void.
Could anyone let me know if the following setup sounds correct? I have never done anything like this before.
I plan to connect the AV receiver to the TV by a single HDMI cable (i also plan to run a spare HDMI Cable from the TV for future use).
The DVD player would then be connected directly to the receiver by HDMI and Digital Optical cable (for suround sound).
The SKY+ box would be connected via S Video to the receiver and again digital optical cable for surround sound.
I plan on using flat speaker cable to connect the speakers, this is so that i can run the cable under the carpets. I have been looking at two types: QED Qontour Ultra Flat and Merlin C4. Could anyone offer advice on which is better, or any other alternatives? I'm looking at paying no more than £2 per metre so cost is important in this instance.
As far as the speaker connectors go, would i be correct in thinking that i need to go for banana plugs? If so i will i need 20 of them? Any advice on the type i should be looking at would be appreciated.
A sub woofer cable would run from the receiver to the sub (i think 😱).
The only other cable that i belive may be required is an 'on screen menu' cable for the receiver menu to be displayed on the TV. Do i need this cable? I was rather hoping that everything would go through the single HDMI cable...
I hope at some point to get a Playstation 3 (which may well replace the DVD player) and possibly a Nintendo WII, but for the time being i have a budget of around £2000 so they will have to wait!!
Am i correct in thinking that the PS3 would be connected in the same way the DVD player is above and the WII by component cable and digital audio?
Any ideas or suggestions on the way i plan to set the equipment up, or the actual equipment i plan to use will be gratefully received. i plan on having a demo of the above equipment nearer to the time of purchase so that i can confirm that i like what i hear and see!!
Many thanks in advance
Richard
Richard
