Home automation, remote controlled mains & 12V triggers
busb
115
32
18,620
My newish Primare power amp is currently placed on top of my ancient Target rack for the simple reason I can easily access its rear mains switch. I will be replacing this rack perhaps with a HiFi Racks podium or similar later this year where the amp will be nearer the floor.
With this in mind, I bought a set of these radio controlled mains sockets:
http://www.amazon.co.uk/gp/product/B008XNY7A0/
one of which my amp is powered from. I haven't noticed any impact on SQ but if I experimented to find there was, I could then try remote controlling a 12V PSU into the amp's trigger input instead. The main problem with these DB-Tech sockets is their bulk - an issue when plugged into a mains strip. Can anyone suggest sockets that are slimmer? Infrared control maybe more benign interference wise but needs line-of-sight to work, so radio control would be needed. Any experiences with home automation would be gratefully received. The DB-Tech's transmitter is also quite bulky so would also be interested in a RF & Infrared universal remote at some point.
Home Easy. I have tried several and these seem the best. Most interfere with adjacent skts but these seem least prone ime. SQ? I dont know. Let us know if you experiment. Only my TV is switched tho a plug since the amp & bd.go thru the PureAV box.
Hey Robin
Thanks for that but their sockets only seem to handle 300W. However, Home Automation looks to be the way to go. I'll do some more research.
Savasocket is infrared and has an outboard ir sensor so can be hidden away. I use two for my speakers and sub, work well.
http://www.savasocket.com/products/multi-socket-6.html
