High powered amp and volume adjustments
hybridauth_Facebook_664715932
84
Hi all,
With two young ones at home i don't get to listen to music very loud.
Since i got the tucana i am noticing how quickly it goes loud and loud to very loud on the volune knob. I have had the amp almost a month and only now i am kind of getting the hang of it and that is only on the remote not on the actuall knob. I read on the iceman's mfams35i thread that other people were having similar issues.
At the moment my sweet spot is about 7 30/8 o'clock position. With tucana i have not gone past 11 o'clock position i am scared it will damage the speakers.
ChrisIRL
36
A dac with an adjustable output such as the Chord Mojo would help here. In the evenings I reduce it's 3v preset output to a level that allows for more control with the amp volume. The Mojo audio signal comes directly from the fpga chip with virtually no distortion so you don't have any double amping issues as you would using some dacs in pre amp mode.
iceman16
Animesh Ghose said:
Hi all,
With two young ones at home i don't get to listen to music very loud. Since i got the tucana i am noticing how quickly it goes loud and loud to very loud on the volune knob. I have had the amp almost a month and only now i am kind of getting the hang of it and that is only on the remote not on the actuall knob. I read on the iceman's mfams35i thread that other people were having similar issues. At the moment my sweet spot is about 7 30/8 o'clock position. With tucana i have not gone past 11 o'clock position i am scared it will damage the speakers.
Hi Animesh.. off topic.. have you seen my YT videos?
Deleted member 108165
Animesh Ghose said:
Hi all,
Have you considered adding some Rothwell passive attenuators to calm the input from the SA8005?
84
iceman16 said:
Animesh Ghose said:
Hi all,
yes i did, very nice indeed, love those heat sinks. Should have done a close up shot
84
DougK said:
Animesh Ghose said:
Hi all,
never knew such a thing existed.
Animesh Ghose said:
DougK said:
Animesh Ghose said:
Hi all,
Here: http://www.rothwellaudioproducts.co.uk/html/attenuators.html
Got them fitted to the inputs on my amp, -10dB variety adds about 2 hours to volume dial sweep. I have tried other makes but Rothwells are the best - totally transparent. Not sure if this is what you need but I'm sure others will chime-in if I'm pointing you in the wrong direction *smile* Vlad will be the guy to ask...
Vladimir
220
7
Gain Button The gain button allows the input gain for each input to be varied over a range of +/-10 dB using the volume knob. The gain setting of each input is independent and will not affect other inputs. With this facility, the audio level of each source can be made similar. For example, CD players will often sound louder than Tuners or MP3 players.
Using the gain facility, the gain of the CD input could be reduced and/or the gain of the MP3 input increased to achieve an audible match.
To do this, first listen to a selection of input sources to judge an average volume level.
Set a comfortable volume level using the volume control. Note that selecting between inputs will reset the volume to a low level. To judge the average level, the volume should be reset so that the LED ring indicates the same position.
Next, make a note of any sources that are louder or quieter than the average level. If a source is louder, press GAIN, and adjust the volume knob down to bring that source back to the average level.
Press GAIN again to return to normal operation. If the source is quieter than the average, press GAIN and increase the level using the volume control.
Now when you select different inputs, the level will remain similar for similar LED positions on the LED ring.
Source
chrisr1718
52
DougK said:
Animesh Ghose said:
DougK said:
Animesh Ghose said:
Hi all,
I just started another thread about these, I think that answers it for me. *biggrin*
DougK said:
Animesh Ghose said:
DougK said:
Animesh Ghose said:
Hi all,
Good suggestion those attenuators, there is another thread on going about them.
Should solve the problem.
Added bonus: With them fitted to the amp inputs from my cdp they have also resulted in equalizing the volume output of the cdp and turntable, so I no longer have to dive for the volume control when switching sources.
84
Source
thanks for that
chrisr1718
52
DougK said:
Animesh Ghose said:
DougK said:
Animesh Ghose said:
Hi all,
Mine arrived today and they worked a treat. *good*
