High Level input cable for sub B&W PV1
dakchi
18
Hello,
I had a quick question to ask the people who have B&W PV1 or PV1D subwoofer: I would lile to connect it with a Marantz PM6005 through the high level input. I think that I have lost the cable for that. It's a RJ11 cable like a telephone cable. Where can I but one? can I simply use any telephone cable?
Many thanks for your help
spiny norman
293
Well, it's a cable with a telephone-type connector at one end, anyway.
Just a wild stab in the dark, and this is probably going out on a bit of wacky limb so forgive me, but how about connecting B&W costomer support and finding out how much a replacement would cost? ;)
dakchi
18
Thank you for your response. Well, if I contact the customer support, I know that they will sell me the téléphone cable for 100€. So I was hoping that someone can confirm that a normal telephone cable can do the work
JamesMellor
40
It's very hard to tell looking at the manual what kind of plug it is , are you sure its RJ11 ? thats 4 twisted pairs of very thin solid core cable
James
dakchi
18
James
Yes it's an RJ11. I would appreciate if someone take a picture of the cable and send it to me?
Thank you
grahamrider
The manual suggests it's a molex connector but does not identify which colour wire is connected to which pin.
dakchi
18
yes it's in the manual:
Yellow Left +
Green Left -
Red Right +
Black Right -
just like a telephone RJ11 cable :exmark:
grahamrider
Hi
For Rj11 telephone cables are available in most electrical suppliers eg maplins. PV1 and PV1D use different connectors !
grahamrider
Hi
This suggests that a heavier gauge cable is not necessary (taken from PV1D manual; assume alsoapplies to PV1
1. Speaker level stereo inputs – Molex socket
This option is provided if you are using an integrated
amplifier with no line level outputs. A special cable is
supplied that has a Molex plug at one end and bare
wires at the other. As the input impedance of the PV1D
is very high compared to a passive loudspeaker load,
there is no advantage in having a heavier gauge cable
and the PV1D may be connected in parallel with your
main speakers without compromising the load on
the amplifier.
The colour coding of the free end of the cable is:
Yellow Left +
Green Left -
Red Right +
Black Right -
Note: On delivery, the PV1D is configured to use
line level inputs. If you want to use speaker level
inputs, you must first configure one of the Presets.
See section 5.4 for more details.
frieddr
Hey did you ever figure out how to hack a high level speaker wiring harness for the B&W pv1 subwoofer? This item appears to be no longer sold by the factory. Apparently the wires for the newer pv1d is different...
ASK THE COMMUNITY
