High end iPod headphones
Aslan
26
Can anyone recommend good headphones for use with an iPod? I would like a pair with closed backs, good for travel, foldable if possible and something strong and difficult to break. They also need to look fairly sensible and not the sort of thing Ali G will be proud of.
Budget of up to 1,000 quid.
I have read some reviews of the Ultrasone Edition 8 and I am really tempted to buy a pair based on what I have read. There are a couple of websites I have come across which desribed them as being the best iPod headphones. However, they are quite expensive at around 900 quid.
I travel a lot in my job and I find that I end up spending a lot more time listening to my iPod than I do my main hifi system. I will only listen to my headphones using an iPod (or something similar) and am unlikely to use a seperate headphone amp or DAC.
I currently use a pair of AKG450 with my 4th generation iPod Touch. I listen mainly to rock, pop and some opera. The music is compressed to 256kbps.
Are these headphones a bit over the top for use with an iPod?
Can anyone recommend alternatives and less expensive models which I should also audition?
Many thanks for your thoughts and suggestions.
dalethorn
2,222
Based on my last 50 headphones, the very best sound I've gotten with the iPod, insofar as a fairly neutral sound is concerned (a la the Ultrasone 8) is the v-moda M80. Very rugged, small and light, comes with carrycase, can be carried comfortably around the neck all day. For Ultrasone 8, Ken Rockwell has a good review.
jjbomber
Ali G would go for the Grado GS1000i cans. Loud, proud and very obnoxious, especially to those sitting next to you.
Me, I'd go for the Sennheiser HD800 because I am totally biased in favour of Sennheiser.
dalethorn
2,222
Sennheiser 800 is too inefficient to play most music tracks on an ipod. And it's very cumbersome as a portable, and open back.
Audiofoolius
33
The Beyerdynamic T5P is an excellent headphone. http://www.whathifi.com/review/beyerdynamic-t5p
They are more comfortable than the Ultrasone Edition 8 imo.
Harry Palmer
12
Hi there,
A curve ball maybe but for the cost that you're considering I would take a serious look at a custom pair of monitors from ACS.
These are the professionals choice and I use them personally. I've owned several pairs of conventionla major brand headphones over the years for different types of listening but these are by far the best, especailly when travelling. As they are moulded to fit your ears the listening levels are much lower, protection to your ears is second to none and they couldn't be more comfortable.
They're not easy to track down as a consumer but some Sevenoaks sound and vision stores are carrying them according to the sales person I spoke too.
http://www.acscustom.com/uk/index.php?option=com_content&view=article&id=98&Itemid=78
Maybe contact ACS direct or Sevenoaks head office to find out what stores carry them?
Good luck
philipjohnwright
30
I'd question the need to spend anywhere near £1,000 given your criteria. I too have music on my iPhone (iPod - same difference) at 256kbp, finding it a good balance between capacity and sound quality. I also use closed back phones that are portable and fairly tough. Namely the £50 Sennheiser PX200's; lovely sounding phone that I prefer when travelling to a pair of Etymotic HF5 IEMs that are about twice the price (they're more brightly balanced even with a good fit to the ear, which can be dificult to achieve at time).
The iDevice can drive the 200's to high volumes (unlike my Senn 650's.) I do have a Ray Samuels external amp that i tend to lug around as well. Really small - you might want to reconsider not having one as it does make a big difference sound wise. Not saying it has to be an RSA one, there are others around. Mine was used off eBay for £150, I think you can get RSA's modelsfrom around £300 upwards new directly from the USA. If I was buying again I'd get one with a Dac as well to use with my laptop, but that may not be a requirement for you.
Finally I am fussy about sound (I used to have B&W Nautilus 802's), so it's not just that my standards are lower. Just that in practice I think I've reached the point of rapidly diminishing returns for music on the move
Aslan
26
Unfortunately, I read Rockwell's review of the Ultrasones, that is what set me off and now I want a pair. I wish I never read it! I will check out the v-moda but not sure about their availability out here in Hong Kong.
The HD800 looks great but I think they are more suitable for listening at home as they aren't very portable.
The Beyerdynamic T5p looks like the sort of thing I am looking for, I will definitely audition these alongside the Ultrasones.
I have never liked in-ear phones and even though the ACS are probably an excellent choice, I don't think I would ever feel comfortable with them.
I am not certain whether a 1,000 quid pair of iPod headphones is a good idea either, which is why I asked for recommendations of less expensive alternatives. When I travel for work, I carry as little as possible. I will not take a laptop or iPad unless I really have to. My iPod Touch is all I really need. An external amp/dac will probably also make a big difference, but I would not want to have to carry it and its chargers with me. I think I will just need to compare the Ultrasones and T5p to my 50 quid AKGs and see if it really is worth it.
Thanks for all your suggestions :) .
dalethorn
2,222
I would expect the t5p to be much less efficient than the Ultrasone - don't know for sure, but best to check if using only the ipod.
Aslan
26
I just popped into a train spotter headphone shop near my office. As soon as I looked at the Ultrasones and then the T5p, the salesman knew exactly what I wanted to buy and told me that they were the only 2 choices. I got the impression that many people have been to his shop looking for exactly the same thing as me. Good to know I am not the only nutter out there.
I did not audition them as the Ultrasones are pretty expensive compared to what they are going for in the U.S.A. at US$999. I need to shop around a bit but I might have to order them over the internet which is something I really don't like doing.
Aslan
26
I have not auditioned the T5p yet. I want to audition them together, I will check out some other shops first before I audition them.
dalethorn
2,222
Make sure to audition on the ipod, to check maximum volume with your tracks that have lower volume.
dalethorn
2,222
Since this is going every direction now, and cost is no object, might as well go for the gold, eh? Portable, durable, great sound, cost no object.
My starting list and notes:
Beyer DT1350. Earpads don't seal quickly in cool weather; slight comfort issues; tends to have hollow mids.
German Maestro 8.35D. Slight comfort issues.
Philips Fidelio L1. Slight comfort issues; extra strong bass.
Sennheiser Momentum. Fairly strong upper bass.
Shure SRH940. Fairly bright treble - fixable with Dale's earcup foam mod (non destructive).
Vmoda M80. Slight comfort issues; earpads don't seal quickly in cool weather.
Vmoda M100. Extra strong bass.
With this list, I excluded items that weren't portable (able to pull off head and around neck so packing into carry bag would not be *immediately* necessary) and weren't durable. I also excluded some fairly decent portables whose sound fell below the arbitrary hi-fi level I figured would go along with cost no object.
daytona600
649
363
19,270
£1000 headphones bit over the top for a Ipod , buy one of these ak100 astell & kern for £500 & £500 headphones
best portable i have heard by a country mile on sound quality , does all the apple formats + 24bit/192khz flac/wav files as well
also has a excellent headphone amp built in , plug into your hifi use built in pre-amp and you have a digital transport that beats most £2000 cd players as well
http://www.youtube.com/watch?v=Fx8pGAne_2Y
http://www.youtube.com/watch?v=6M_StLiGZrU
Aslan
26
Thanks for all your suggestions. I ended up buying a pair of Sennheiser Momentums.
I tried the Beyerdynamic T5p, they were really nice but I didn't think they were worth 2 or 3 times as much as the Momentums. I auditioned them in a noisy shop and I guess they would sound much better in a quiet environment.
The Bose Quiet Comfort 15 had excellent noise cancellation and would have been perfect headphones but I found that they put pressure inside my ears and felt really uncomfortable.
I didn't bother auditioning the Ultrasone Edition 8 as they are really expensive in my market compared to the U.S.A. I see no reason why I should pay 20% more than the Yanks. They did look very very nice though.
Since I have a little money left over I think I might check out the AK100 or a new iDevice.
I have a 20 hour train journey coming up soon and I think my new Momentums will make the journey a little more pleasant.
Thanks guys.
