Hi! new to hifi & need help setting up speakers
It's probably ok, you're using the B speaker outputs, have you selected the B speakers on the amp (it's probably a switch on the front panel, I haven't checked)?
Hmmm..... looks ok. Just to check: -
1) Are you sure the speaker output selector on your amp is set to B?
2) Are you sure the amp itself is working? (Lights come on at the front, no blown output fuses etc.)
3) Do you get any sound if you single wire?
