Hi all,
I'm thinking of purchasing a hi-fi system for %75 music and %25 movies. I thought that NAD 375 bee would be a good amp as it has an internal DAC so i can connect the TV via optical out (is it a bad idea by the way?) and also stream with Apple Tv.
I listen to a wide range of music metal, rock, jazz, electronic... So as for speakers i'm confused a lot. Lots to choose from. I read good reviews about Tannoy Precision 6.2 but there is not much info about those and i cant demo them. I demoed Focal 826, while they were really clear and good with jazz tracks they were very closed with other genres. Other options maybe B&W Cm9, Sonus Faber Venere 2.5, PMC 23 or any others you can recommend.
