Hi Fi Rack for Michell Gyro SE
Can any one suggest a rack for the Gyro SE?
I've currently got a cheap rack which needs replacing as it doesn't fit my moon kit properly, but looking at the Atacama Equinox and Europa racks they are only 500mm deep, where are the HWD in the whathifi review states the Gyro is 530mm deep (and 410mm wide)!
Given i'm going to audition the Gyro and various other t/t's of varying sizes i need to buy one that will fit any of the contendors
Any suggestions (other than a wall shelf) would be appreciated.
Many thanks
Try the Ikea Eina, should be deep enough. Change the wheels for spikes and you've got yourself a decent stand. Alternatively use a Lack for the Gyro alone.
Yes, JD has it right, the dimensions are 19" W x 15" D x 5.5" high, which translates to 48.2cm x 38.1cm x 13.97cm.
Did i read this wrongly?
http://whathifi.com/Review/Michell-Gyrodec-SETecnoArm-A/Specs/
Thanks, i had a quick look on the Michell website and couldnt see them!
