Help!
Hi.
I want to move into the (for me) very confusing world of Computer based HiFi. :type:
My system is currently CD only, but I want to move to a server based system. (Hundreds of CD's - tired of trying to find THAT disc....) :wall:
A few years ago I had an iMac wirelessly streaming iTunes to an Airport Express unit feeding a DAC.
The sound was flat and grey although the DAC (Audio Alchemy DDE V.3 - an oldie but goody!) sounded great when fed from a CD transport.
I went back to a CD player after a few months as I hated the dull, lifeless sound.
I want the very best sound I can achieve, but my experience so far has put me off making the move.
I'm considering using either a Mac Mini or Unitiserve feeding a Chord QBD76HDSD DAC. :?
Questions:
1. The Unitiserve apparently rips bit-perfect to its hard drive. The Mac mini needs a USB driven optical reader to rip a CD. Even using a bit-perfect ripper, will I get the same quality rip?
2. The Unitiserve is more than twice the price of the Mac mini, but it is a piece of HiFi equipment, will I get equally good sound from either unit?
3. I will want to use Hi Res files in the future. Am I better with the Mac mini to do this, or is it easy enough to get these files on to the Unitiserve?
4. My previous experience has really put me off WiFi streaming, so I think I'd prefer a wired connection. Am I right?
5. Finally, streamers. - Are they as good as a CD player £ for £?
I'm hoping someone out there can point me in the right direction...... :help:
I would revisit your previous iTunes setup and first ensure that the music has been ripped to a suitable format and bitrate.
Debate will rage as to where the compression of an audio file becomes audible, but I happily use 192 Kbps VBR AAC files without issue. I have these on my Macbook, but my Mac mini stores the 'master' rips of lossless ALAC files.
If you already have an iMac and iOS device, such as an iPhone or iPad, I cannot think of a more convenient way to do things.
To answer your questions...
Yes
No reason why not.
I don't know. I have never and would never consider a Unitiserve, I'd be more inclined towards a Synology NAS.
Depends on the quality of wireless connectivity in your house. Thick stone walls in cottages, for example, can play havoc with a wireless signal and a wireless extender would be needed. A wired connection obviously avoids any potential issue, but I have had none.
Yes and theoretically better.
Hi.
Thanks for that.
All my files are ripped in Apple lossless, but when I streamed them, everything just sounded flat and one-dimensional.
I think what I'm going to do is go for a DAC and do some experiments with my MacBook Pro (via USB), to see if a Mac as a server will work for me.
