got the new epg over night and now my box says not sat signal being received, when i look at the signal it has a signal and is locked on. is this problem linked to the new epg or is it seperate problem. any ideas before i spend half the evening on the phone to sky
VoodooDoctor
81
Have you turned it off at the wall and then restarted it? Sometimes the box needs rebooting to get it to behave again.
Tonya
57
Oh dear!
This is a known issue after the SkyHD EPG update shenanigans, as it appears at first glance to change the default transponder settings.
If you don't have a really good signal on this particular transponder, you will experience the symptoms that you are describing.
Try the following exercise, it appears to work for some but not all . . . .
1. If at switch on it says no signal and a number in the video window box then do the following.
2. Press the Guide button.
3. Go to the top (****tions) bar.
4. Scroll through to the Settings menu.
5. Scroll down to Picture.
6. then press 0 then 1 then Select after each other to get to installer menu.
7. Scroll across to TX`PONDER.
8. If it says 11.856 V change to 10.714 H.
9. Exit, then reboot.
Depending on your signal levels, it may just do the trick.
Good luck!
Thanks Tonya i will give that a try as i do have a weak signal at times
thanks tonya but that did not work i now have no signal reading where as before i did
