Hi guys am new here so please be gentle!
I have the AX863 but can't seem to get it to use the sub in anything other than DTS/DDig modes. When I watch any 'analogue' signal it just uses the front two, which is not much use when you have a sat/sub system! I also can't seem to get it to into ProLogic mode, and instead get "Enhanced" through 2 speakers which is rubbish. It works fine when fed DTS/DDig so I know all the speakers are ok and the amp's working. Even the little picture on the display shows only the front 2 speakers! I've trawled the manual but can find no answers there. I've had several receivers over the years of different makes and this is the first one I've had the problem with.
The sources are a PC and a V+ box fed using Optical cables.
Thanks in advance!!!
