help with me turntable connection....
hi guys i recently bought a new hi-fi it s a Denon Denon RCD N-7 lovely system and i also bought a project essential turntable also nice, no my problem is there is the 2 usual phono cables from the turntable but there is also an earth wire but nowhere on the Denon to connect the earth wire to so after the phono wires are connected sound can only be heard from one speaker when Denon is turned up to max volume any help would be cool.....thanks.
nads
908
257
19,270
the turntable is connected to a Aux in? you will need a Phono stage (amp) to connect the turntable to and then connect the Phono stage to the dennon.
yeah its conncted to thru the aux in, so basically in need an amplifier... :) i thought it would be able to connect direct to Denon, so what amp would you recommend, thanks for reply i'm new to all this stuff :)
would something like this do the job? http://www.ebay.co.uk/itm/PHONO-RCA-TURNTABLE-RECORD-PLAYER-PRE-AMP-/220820874722?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item3369f325e2#ht_871wt_1037
or this
http://www.ebay.co.uk/itm/230671726235?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_3208wt_1270
thanks chebby, what would happen to the earth wire from the turntable?
ok cheers guys for all help ill try this out and see what happens.
oh thanks for the info, now i will buy and dust off the old vinyl :)
