Help with fixing Tannoy Revolution speakers
jabol
11
I hope all is well. I have owned Tannoy Signature Revolution speakers for a few years. I have just noticed that one silver rings (around the driver) is a bit loose. If I press it, then it looks ok, but, after a while, I can see it not adhering properly. What glue/fix I can use? Your advise is greatly appreciated.
Thank you!
Anderson
That's not good. I wouldn't feel comfortable recommending a particular glue so send Tannoy an email or give them a ring for advice.
