- Aug 10, 2019
- 2,556
- 4
- 0
Up until recently I was running a Humax digital PVR into our old Phillips (non flat screen) telly with no problems. Then I took delivery of a BT Vision PVR and home hub and a Panasonic DMR EZ47V video and DVD recorder. I am using a "Oneforall" signal booster to keep the arial signal strength high. Problem is that whenever I add the Panasonic to the set up I start getting intermittent RF noise. I have spent hours trying different set ups and cable runs but the problem keeps coming back. Unplug the Panasonic - noise goes away. There is a loose sheet in the Panasonic paperwork that says the unit MUST be connected to the arial and TV with the cables provided otherwise RF noise may occur. I have done that but still get the problem. Can anyone advise 'cos this problem is driving me right round the bend?
Gray D
Gray D
