- Aug 10, 2019
- 2,556
- 5
- 0
Hi all,
Doing quite a bit of research before finally letting my wallet loose - I have a few queries regarding production of HD sound from Blue ray disks....
From what I understand, there are 3 ways of decoding HD sound to drive the speakers (can you confirm this is correct - as the possibilities are driving me mad now):
1.) HDMI - BD Player passes picture and music to Receiver via HDMI. Receiver seperates and decodes the HD signal from the HDMI input to drive the speakers. Receiver requires the ability to decode HD signal and receive HDMI, Player needs very little capability (other than HDMI out).
2.) Multichannel - BD Player decodes HD sound signal and passes to Recevier via Multichannel (analogue) connections, picture being passed via HDMI to either Receiver or straight to TV/display. Receiver requires Multichannel and HDMI inputs, Player needs multichannel outputs. Connection between Receiver and Player is made with a HDMI lead and 4 pairs of RCA Analogue leads (for 7.1).
3.) LPCM ** - BD Player decodes HD sound signal and reencodes as LPCM - the LPCM signal can either be sent via
3a) digital coax,
3b) optical digital,
3c) or over HDMI, coupled with the picture signal.
** This is really where my knowledge gets fuzzy - if a Receiver supports LPCM, can it strip the decoded HD audio from any of the above inputs (3a, 3b, 3c)??
Also, which of the above will give the best sound overall?
Many humbled thanks in advance.
3a) digital coax,
