Help required on dipping my toe in the music server arena!
OK, so after hearing the NAIM HDX and being blown away by by its usability I want something similar. So, i'd like some advice on my options, here's the criteria/options:
Budget = £250 - £500 hence, I cant afford the Naim HDX 🙂
Sound quality and convenience/usability are of equal importance, this means for me I dont want to use my PC for a music server as I dont want the noise, power consumption, etc
Options:
1. Something like the Cambridge Audio music server would be ideal apart from having to re-rip my entire music collection! (unless it supports external drives?)
2. I could buy an ipod classic and arcam r-doc?
3. Get something like the Naim but cheaper? Like the Linn Sneaky DS and External drive?
So what's my best option for Sound Quality and conveniance?
Also, most of my music is MP3 or WMA in 190 to 320kbps, should I start ripping in FLAC or WAV??
Start slowly. Sounds like you have a colleciton ripped to PC already, so play them through your hifi via a wired or wireless client. You could do that with Airport Express or Squeezebox AND a decent DAC like Beresford or DACMagic at either end of your budget.
Unless of course you want it all self-contained.......
hmm...I do have a 40gb collection but dont want to use my PC as the source since I dont like leaving it on. Its only on as required, usually to rip or burn a cd.
So i dont really want the wireless music sender option...sorry 🙂
Really I want a cheaper Naim HDX (but no PC solutions please) and preferably with an external HDD
Does anyone make something like the Linn Sneaky but without the amp?
You can use a NAS, which stores the music and has a lightweight server running - ripcaster is the place to look, they do NASes with Squeezeserver preinstalled?
Thanks JD
I actually stumbled accross Ripcast - great site.
All the solutions just seem to be a bit industrial!
Does a squeezebox support NAS or external HDDs?
You want something like a Sony NAC HD1.
However, I would recommend buying a small laptop for music at less than £300, and spend £100-£200 on a DAC.
Thanks, the laptop could work but my listening room is quite minimal and I dont really want a laptop sitting on my system.
I'll look at the sony...
I like the look of the sony. I read it has a usb interface but wonder if it supports external HDDs?
I also cant find any reviews apart from press releases which dont mention what bitrates it supports or whether it has pre-outs....
Reposted / "Moved" to the Computer Based Audio Forum.....
Please reply there 🙂
