Help please: How to tell an Arcam CD72 from a CD72T???
Hi Folks,
Can anyone tell me how to tell an Arcam CD72 from a CD72T??? There's one in the paper for £75!...not saying which paper!!!
Much thanks,
Jack
Well, I guess if you could get hold of the serial number it may have something to indicate which version it is, or if not a phone call to Arcam with the serial number should lead to the answer being forthcoming.
Andrew Everard:Well, I guess if you could get hold of the serial number it may have something to indicate which version it is, or if not a phone call to Arcam with the serial number should lead to the answer being forthcoming.
Absolutely - just seems a lot of hassle when Arcam could just put 'T' on the front. . .I'm a misery.
Should have a logo on the packaging and disc saying 'Compact Disc Digital Audio', with the word 'text' underneath it.
Andrew Everard:Should have a logo on the packaging and disc saying 'Compact Disc Digital Audio', with the word 'text' underneath it.
Are you sure you're not a secret Arcam lover?
JoelSim:
Oh no, I feel the pipe and slippers are going to be given an airing. . . .
"Should have a logo on the packaging and disc saying 'Compact Disc Digital Audio', with the word 'text' underneath it."
....as does the player! Bottom left corner of the front panel.
Cheers folks,
Jack
JoelSim:Are you sure you're not a secret Arcam lover?
No, just a bit geeky when it comes to disc standards and the like...
Joel or someone else with an Arcam may be able to confirm my theory, my CD82T serial number starts C82T maybe CD72T starts C72T?
Aha solved it Sept 2001 pg 60 "All the new [CD72T] models will have a serial number starting with C72T" sad aren't I?
Andrew Everard:
I know this is more a format question, but does it drive you mad when you get competing formats from manufacturers that seem to confuse the public and struggle to get true support from the labels - SACD/DVD-A for instance? That's my geeky thing. And it drives me mad when they get it wrong, much as I enjoy SACD.
