[Help] Only 35cm deeper to put my HC amps...
Hi, i search a good amps ( average 400€) but my space it's smaller... I ve only 35cm for put home cinema 5.1 (or bigger) amps and naturelly conneted all cables...
Can ou help me to find the best solution?
Thanks Lionel
no reply ...
I can't really help, but your cabinet looks nice!
I suggest you check sizes on amplifier manufacturers' websites, or ask a good store if you have one near your.
You'll probably want to avoid Onkyo amps, as they run very hot!
- Nice cabinet, by the way.
Thanks for your intervention; i ve perced many hole in top of cabinet but it's real my installation don't like hot machine!
Nothing else?
