- Aug 10, 2019
- 2,556
- 5
- 0
Hope someone can advise
Have recently purchased an older setup (Pioneer A400 amp, Marantz CD53-mk II sig CD player, and an old pair of B&W DM2 3 way transmission speakers (the very 1st edition)
Have ordered the SILVER HIGH BREED Coherence LE Interconnects and will be ordering silver high breed speaker cable later today
I will need to place the speakers on stands ... speakers are heavy and weigh approx 23kg each ... dimensions are approx:
25 1/2 inches high, 14 inches wide and 13 1/2 inches deep ...
not sure what height speaker stands I will require, but based on info I have read, I need to raise them approx 40cm (16 inches)??
I have searched ebay and google, and the original stands that were sold with these speakers are the small stands made of square tubing with wheels/castors on the base ...
I need suggestions on good stands ... The Partington super dreadnaught stands are approx 60cm high (20 cm higher than required), and the atacama stands are also approx 20cm too high ..
will the extra 20cm height make a huge difference? .... or is there a better option of stands? ... if the base has adjustable spikes, is it good practise to have the back spikes a bit higher so as to compensate for the extra height in the stands?
Also .... once I get stands (most prob 2nd hand off ebay), .... how do you mount the speakers on the stands? ... do you use 4 spikes connected to the stands, then the speakers rest on the spikes or is there a better method? ...
I have also read that it is good to use a granite block on the carpet, then place the stands with bottom spikes onto the granite (may possibly buy granite offcuts from our local kitchen specialist if available and cheap)
sorry for my ignorance, but am fairly new at this!
