Help - LCD vs Plasma Again (sorry!)
Please help me decide....
I was just about to push the button on a great deal on the Sony 40z4500 LCD when I got a bout of the doubts and though perhaps I should be going plasma....
I can not go over 42" in my room as there is a gap in my bookshelf for the TV that is only 105cm....this does seem to rule out a lot of Plasma sets which are 42".
The 40" Sony will fit like a glove and it seems to only get great reviews.....I watch a real mix of Blu-ray, DVDs and Sky (i do have Sky HD but the lack of channels means its usually SD).
I just cant get to look at the two side by side - and as time is precious at the mo - an audition is probably not going to happen - so do I go for (slimline) 42" Plasma, or go for the 40" z4500 sony???
I have always envied my mate's Pioneer Plasma - although they are too big to fit in my space.....My max budget is £1,300....
Really grateful for opinions!
thanks
Alex
yiannis550
38
I was going to buy an LCD. Then one day I happened to be in a store where they had Samsung 6 series plasma and LCD next to each other playing casino royale. Although the LCD was brighter, giving it a closer look I noticed that the plasma had more details. For example a person wearing a black jacket, on the LCD would be a black jacket, but on the plasma it would be a textured black jacket. The road on a dark scene, on the LCD was a black tarmac road, but on the plasma it had little stones and water puddles! I guess WHF magazine people would call that deeper blacks:)
After that I started noticing that no LCD (even the expensive philips ones) had as much detail as the plasma tvs in a store.
The final strike was when I saw the pioneer KURO 5090H in a store. It was breathtaking with blue ray. I went over my budget which was 1800 euros and ordered it at a discounted 2200 euros. I never looked back! This will delay my plans to buy speakers and amp for few months but it is ok. The KURO worths the wait...
I hope this helps...
Have a look at the Panasonic plasmas. They're in the process of launching a new range (all of which are almost guaranteed to be great) or you could pick up a 2008 set at a bargain price. Either way you should have plenty of change from £1,300. Spend some of it (~£250) on getting your set ISF calibrated. It's well worth it. Much, much better picture quality than any LCD I've seen to date.
Plasma television technology is based loosely on the fluorescent light bulb. The display itself consists of cells. Within each cell two glass panels are separated by a narrow gap in which neon-xenon gas is injected and sealed in plasma form during the manufacturing process. The gas is electrically charged at specific intervals when the Plasma set is in use. The charged gas then strikes red, green, and blue phosphors, thus creating a television image. Each group of red, green, and blue phosphors is called a pixel (picture element).
Although Plasma television technology eliminate the need for the bulky picture tube and electron beam scanning of traditional televisions, because it still employs the burning of phosphors to generate an image, Plasma televisions still suffer from some of the drawbacks of traditional televisions, such as heat generation and screen-burn of static images.
LCD televisions, on the other hand, use a different technology (see also question #1 for this same explanation).
Basically, LCD panels are made of two layers of transparent material, which are polarized, and are "glued" together. One of the layers is coated with a special polymer that holds the individual liquid crystals. Current is then passed through individual crystals, which allow the crystals to pass or block light to create images. LCD crystals do not produce their own light, so an external light source, such as florescent bulb is needed for the image created by the LCD to become visible to the viewer.
Unlike standard CRT and Plasma televisions, since there are no phosphors that light up, less power is needed for operation and the light source in an LCD television generates less heat than a Plasma or traditional television. Also, because of the nature of LCD technology, there is no radiation emitted from the screen itself.
Plasma vs LCD
The ADVANTAGES of Plasma over LCD are:
1. Larger screen size availability.
2. Better contrast ratio and ability to render deeper blacks.
3. Better color accuracy and saturation.
4. Better motion tracking (little or no motion lag in fast moving images).
The DISADVANTAGES of Plasma vs LCD include:
1. Plasma TVs are more susceptible to burn-in of static images.
2. Plasma TVs generate more heat than LCDs, due to the need to light of phosphors to create the images.
3. Does not perform as well at higher altitudes.
4. Potentially shorter display life span - this used to be the case. Early Plasmas had 30,000 hours or 8 hrs of viewing a day for 9 years, which was less than LCD. However, screen life span has now improved and 60,000 hour life span rating are now common, with some sets rated as high as 100,000 hours, due to technology improvements.
LCD television ADVANTAGES over Plasma include:
1. No burn-in of static images.
2. Cooler running temperature.
3. No high altitude use issues.
4. Increased image brightness over Plasma.
5. Lighter weight (when comparing same screen sizes) than Plasma counterparts.
6. Longer display life used to be a factor, but now LCD and Plasma sets both have at least 60,000 hour or higher lifespans.
DISADVANTAGES of LCD vs Plasma televisions include:
1. Lower contrast ratio, not as good rendering deep blacks.
2. Not as good at tracking motion (fast moving objects may exhibit lag artifacts) - However, this is improving with the recent implementation of 120Hz screen refresh rates and 240Hz processing in higher-end LCD sets.
3. Not as common in large screen sizes above 42-inches as Plasma. However, the number is growing fast, with 46 and 47-inch screen sizes becoming more common, and some LCD sets having a screen size as large as 65-inches also available to the general public.
4. Although LCD televisions do not suffer from burn-in susceptibility, it is possible that individual pixels on an LCD televisions can burn out, causing small, visible, black or white dots to appear on the screen. Individual pixels cannot be repaired, the whole screen would need to be replaced at that point, if the individual pixel burnout becomes annoying to you.
5. LCD televisions are typically more expensive than equivalent-sized Plasma televisions (although this is changing), especially when comparing EDTV Plasmas to HDTV-LCD Televisions.
I have the Samsung LE40B620R, I play my xbox360 on it as well the picture is amazing both on tv or gaming the sound is great as well, all in all I love it at the end of the day everyone has views on which is the best but I prefer LCD over Plasma any day. Also ive just ordered the SERANO S105BG09 black glass stand for £79.99 which was reduced in sale from £89.99 and also the Sony HTPBD36SSE1FIYG Surround sound home system which was reduced as well to £299 from £499 and it comes with a blueray player as well.
robstar63
21
Dont forget the other issue with Most LCD TVs which is that of restricted viewing angles. If you look ata n LCD TV from an angle the colours become bleached. This is much less if any of a problem with Plasmas. Regards
Hmm not sure about that, but then everyone has views I have a fantastic LCD television so I am happy :)
