Hi, wife thought she was helping me when she reconnected speaker cables to our c370 and c270 in bi-amp mode. unfortunetly she connectd both amps speaker cables to the mid connections on one speaker ( MA GR60's ) and crossed them on the other speaker.
when she switched on power everything in the room went off, inclu both amps-which stayed off. aftr changing fuses in plugs-still nothing, except the power amp would come on for a second on orange light then switch off. changed main fuse inside both amps, the c370 went pop fizzle, followed by smoke and a yank out of the power cable from the socket. the c270 power amp just did the same as before-go off aftr 1 second.
question, am more concerned about the speakers considering what happened to the amps, but how to try them out, and would they still be damaged/weakened even if they did both still work.
Ive got a 23 year old kenwood amp thats about 100w. if i tryied one speaker at a time thru the kenwood, would it be enough to show up any probs with the speakers.
any advice would be greatly greatly appreciatted, inclu what new amp/power amp i should aim for as replacements
cheers
cheers
