Guys i need your guidance on the following i do have a pair of B&W CM1 speakers, these are powered up by a Rotel RA1570 (120WPC) integrated amplifier and for low bass i do have a B&W ASW610 sub connected using the pre out.
I have noticed that with some tracks CM1´s start clicking, normally at high volumes, "apparently" this is happening when low bass songs, few questions for you,
* is this a normal behaviour of the speakers?
* is this happening because of too much power coming from Amp. (Be aware that currenlty it´s almost impossible to pass from 75 volume level on Rotel)
* Is there something i can do to mitigate this?I´m wonder if playing with frequency cut on the SUB might help (Currently i do have it on 60Hz)
Any advise that you could provide would be welcome.
Brgds
Brgds
