Hello There.
I have a denon 1910 home cinema amp, will this be ok to run a pair of PMC DB1i's, I hope someone can help, just starting to build a nice little set-up.
cheers, claude
it will run the speakers just fine, but a dedicated stereo amp will give you better sound with music..
Cant seem to find the Ohm rating of the speaker but as long as its not below 6ohms you should be fine. Not sure how they will sound with your amp, hopefully someone else can tell you more about how the speakers sound. I believe the Denon is a warm sounding amp so depending on how you like your sound you would be best to use brighter speakers. But its down to what you like.
