Hello and a bit of advice please.
BigJay
Hi there,
Have just decided to go for a new Home Cinema Av Amp and Speaker package.The one I have decided to go for is the Denon AVRX2300 Av Amp and the Q Acoustics 3000 5.1 Speaker Package.At the moment you can get both for just under a grand at Richer sounds with a 6 year super care which I think is pretty good value and reviews for both are pretty impressive!
Where I am struggling is what speaker cable should I be going for to get the best out of this system?
Any recommendations ?
Thanks in advance.
Regards
BigJay.
Good shout Simon!
I use QED HDMI Leads and they are excellent.The price per metre in the link you provided is also very reasonable.
Will give it some serious consideration.
Thanks.
BigJay said:
Hi there,
Thanks in advance.
Regards
BigJay.
any good quality 2.5mm copper cable will do ,don,t take any notice of hifi nonsence about magical cables,i got mine from maplin 10awg for £5 a meter
