I still live at home with the folks, i can normaly listen till around 10.00pm before the volume starts getting noticed, i dont mind turning it down, it's very frustrating, the elders have suggested ear phones, i dont really know much about cans, i would like to listen to music late into the night, i dont want to spend to much, i was thinking of addding a v-can 2 with a pair of goldring ns-1000, would that be a good starting point? i will have to connect them up to my dac before i listen, bit of a pain, but if it means i can listen without a knock on the door it will be worth it.
Grado SR80's...
Cant say a bad word about them and very glad I bought them a few months back...
Volume isnt an issue in our house as there's only myself and the wife but sometimes I like to read with some music on so I just bang the cans on my head, forget about the book and fall asleep blissfully unaware of what's going on around me haha...
I dont use a DAC/headphone amp currently but when I get the Cyrus system up & running I'll be looking at getting something along those lines to manage the cans better
eggontoast
453
12
18,895
To help with suggestions let us know what genres of music you listen to.
Mainly rock and pop, some classical, a bit of everything really.
A little more expensive than the Goldring are the Grado SR80i that I have. They really are as good as the reviews say, effortless heaven. I use them plugged into a re-clocked Marantz CD50se powered using RA Reference Power Cord and have never needed to go down the headphone amp route.
Having done a bit of research it seem's the v-can 2 will work fine through the tape out on the caspian, only thing now is decide on which phones to buy, the goldring ns-1000 are top of my list as they can be had for 60 pounds, that's a saving of 90 pound's!
mitch65
52
I have a pair of the Goldrings and whilst they are a bargain at the price they do leak a lot of noise, if you can get past this then go for it. My wife couldn't so I bought a pair of Denon AH-D2000s but 200 quid! just to keep the peace :D
I dont mind if they leak any noise as its just me in my room, i will buy the goldring's, there a bargain.
