Headphones with a softer sound?
dannycanham
If I find things a little crisp and a little clinical wrt headphones, what models would you suggest I try?
Clean, clear, unforced and lacking in sparkle please.
Frank Harvey
567
If you want something smoother than the Grados, try the Sennheiser range, as these are smoother, and easier going than the Grados. The downside is that they're not as detailed or precise.
eggontoast
453
12
18,895
Steer well clear of the Grado SR325is then, they could shatter your teeth !
I would suggest trying Sennheisers HD650, Beyerdynamic DT880, Denon AH-D5000 to start with.
I'd second the sennheiser hd650. It will also partner really well with the burson, which gives it a bit of a well-needed kick. I can imagine the burson, altho smooth, would not be the perfect partner with grados. If you want it still smoother/mellower/more midrangey, use the HRT Streamer usb dac as your computer-compatible source (i notice you say "undecided")
CnoEvil
556
11
I'm generally not a Bose fan, but I've heard some of their headphones that I like. They sounded a bit like you've described. Hope this doesn't make me an outcast. :oops:
