Headphones to turntable?
Chokobolt
41
Hi folks [;)]
So I like to watch the serie House, and I have noticed that when Dr. House listens to his turntable, he sometimes uses headphones.
Can you do that too with Rega turntables, as I am very much considering buying one?
He is using a Sota turntable btw, and when not using his headphones, he uses his Infinity Cascade Model Nine speakers [:p]
The_Lhc
1,176
You can listen to any source through headphones, provided you have a suitable pre-amp/headphone amp in the loop, Greg doesn't have his headphones plugged directly into the turntable...
idc
I have never heard of a dedicated headphone amp that can take a turntable direct as the turntable needs additional amplification (phono card or phono stage). So either he has an integrated amp with a phono card and a headphone output (likely as he also has speakers) or tucked away somewhere is a phono stage connected to a headphone amp and a separate amp for the speakers.
audioaffair
100
idc:I have never heard of a dedicated headphone amp that can take a turntable direct as the turntable needs additional amplification (phono card or phono stage). So either he has an integrated amp with a phono card and a headphone output (likely as he also has speakers) or tucked away somewhere is a phono stage connected to a headphone amp and a separate amp for the speakers.
There is one exception to this - the Clearaudio Nano phono stage with headphone amplifier. In all of their wisdom, Clearaudio created the Nano in two version - the first a phono stage only and the second a phono stage with headphone amplifier included. It's a very small unit but sound quality is very good. This is worth considering. Other options, although more expensive, include going for a Graham Slee Novo headphone amplifier with separate Graham Slee phono stage connected inbetween.
idc
I knew I was tempting fate and there would be one
