headphones for home listening?
kid4today
I'm looking for some headphones for at home listening around the £150 price bracket. I just bought some AKG K550's and to be honest I'm very disappointed with them and will be returning them. whilst i found the sound detailed it seemed to be all high and mid range with virtually no bass at all. I also found them to be very quiet, i tried them on 2 systems as well as my iMac and iPhone and each time had to have the volume on max to get a decent sound out of them. I even found my nocs ns400 in ear phones to provide a better sound than the 550's and they have no volume problem either.
I see the grado 80i seems to be popular, would i be better off with those? sound leakage is not an issue as they'll be strictly for at home use. i listen to almost entirely electronic music, mostly of the 'IDM' genre (aphex twin, boards of canada etc).
i understand that at this price i cant have everything, but surely you can get better volume and bass than the 550's provide.
dalethorn
2,222
The Grado brings together discomfort and less than stellar sound at the same time. Getting good personal advice in that price range will be extremely difficult, and you could post on several boards hoping to get lucky, but it's probably too risky insofar as getting accurate advice. Headfonia is one place I go for independent, accurate, and consistent reviews.
Always pays to do some research first! I think you should buy some Wesc Chambers RZA Premiums (short cable though) at £50 instead of £250. It will save you £100. They will sound superb with your electronic music. Great volume too at only 32ohms. Hope this helps and do report in when you decide.
quadpatch
860
The K550 is a bit of an aquired taste it seems. I wonder about the variance in the sound between units given some people's opinions of them, but a lot is down to the fit too.
I do worry a little about volume, since I seem to remember the K550 being pretty easy to drive. Also the iMac and iPhone both kick out quite high powered output so I wonder whether any full size headphone will be OK for you. Obviously IEMs are far easier to drive so this makes me wonder whether you'll require a headphone amp to be happy with a full size set, but be careful because if this is the case you are at high risk of damaging your hearing.
kid4today
That's exactly what I did, decided to keep the K550's and bought a Fiio E17 mini amp to go with them. The K550's have had some burn in time now, and along with the mini amp, are giving a really great sound. I take back any negative things I said about them......they're awesome!
tom2b
29
Interesting point about the E17.
I too have the AKG550, and share the same observations as yourself. After a lenghty burn in, I totally admire the soundquality and soundstage. But it lacks in Bass .. However hard I try to'enjoy'them, there is just that something that is missing..
I use them on my M-CR603, maybe your solution is something I can consider....
dalethorn
2,222
It's extremely rare that a light bass can be corrected with a bass boost. In headphones that is. Nearly all attempts I've made have failed. One possibility for i-device users is the Accudio Pro app, which has many excellent curves.
quadpatch
860
I agree with Dale, bass boost is tricky thing. Ideally you should hunt for headphones that have a tonality close to what you're looking for. The best way to boost bass that I have found so far is with the Ifi iCan headphone amplifier. I'm not sure that I would advise the iCan as a solution to your problem though.
BigH
114
7
18,595
I have read a few reviews as looking myself for some around this price, the AKG K550s are bass light, some of the Audio Technicas have more bass, try the Audio Technica ATH-A500x.
