Headphone Amp/Amp switch Box
Can someone reccommend a switch box, I have a headphone amp and a separate amp that I want to connect my turntable to but dont want to have to keep switching the cables, so am looking for a switch box, 1 input , two outputs. have tried looking and they seem as hard to find as hens teeth!
Rob
eggontoast
451
9
18,895
It would help if you were to tell us what gear you are trying to connect.
Generally headphone amplifiers are connected from the Rec out of your main amplifier and all sources are connected to the main amplifier also. On 'most' amplifiers the rec outputs are straight through so you can use your headphone amplifier when the main amplifier is not turned on.
ASK THE COMMUNITY
