- Aug 10, 2019
- 2,556
- 4
- 0
I'm contemplating moving all of my AV kit away from the TV to a more girlfriend friendly location (i.e. the other side of the living room, out of her eyeline!).
To do this I will require a lengthy HDMI cable (approx 10m) to run either under the carpet or through the ceiling.
Questions I have are....
1) Which brand (or ideally which cable) should I be using for optimum quality (budget being around £200 max)? I spoke to a guy in Sevenoaks and (whilst standing in front of a wall of Chord cables) he insitsed that QED would be no good at this length and that I needed to invest the extra in Chord? Is there really a significant difference between these brands and is it worth the premium? EDIT: Not that I am restricting myself to just these two brands, just that I have experience of both at shorter lengths.
2) Do I have to consider the shielding abilities of these cables? If I run through the ceiling or around the wall, I will be passing a number of mains outlets and/or lighting fixtures.
Thanks in advance
Ketch
Thanks in advance
Ketch
