HD audio question
cheyworth
145
I have a Pana DMP BD30 blue ray outputting audio as PCM (converting HD sound off the discs) my NAD T-163 Decodes this to surround sound, is this HD audio or do I need to get something like the T-175 HD to get better sound?
Chris
cheyworth:
Chris
Are you connecting the Pana to the NAD with analogue cables via multi channel? If the answer is no, then you are not getting HD audio. If you are, then yes.
If you have the two connected via optical or digital coax, you're not getting hd audio formats, just the good ol' vanilla formats e.g. DD / DTS. I don't think the T-175 can handle hdmi audio either, I think it simply switches it. The Audiolab 8000AP can do what you want or you could add one of these
http://www.tmfsolutions.co.uk/Octava_HDMIto71.htm
d4v3pum4:
Much easier to buy three pairs of stereo interconnects and keep the NAD.
Just checked and noticed the BD30 has analogue outputs, so yes, use those. I do this with my EP35 hddvd for HD audio.
Question guys.
In January i'm looking to replace my receiver & tv & possibly my DVD player.They will all have hdmi connections.Having read here advise that phono cables should be connected to obtain HD audio comes as a bit of a shock,having removed them in favour of optical & co ax audio in my present set up.
I thought that the HDMI cables carried HD sound.Have i got this wrong. I thought hdmi would remove some clutter with them replacing my scarts,didn't anticipate having to re-introduce the phonos.
Digital Optical and Digital Co-axial have insufficient bandwidth to carry HD audio. HD audio can be output as bitstream (raw data) from the player for external decoding by the amplifier (equipped with suitable HD audio decoding) or it can be decoded internally by the player and output as LPCM. This can be transmitted over HDMI or using the player's DAC, decoded and converted to analogue and output over multi-channel analogue cables. The latter method is used mostly by those folks with older amps that lack HDMI.
Phono carries two channels (stereo) but they're just a single length of cable capable of carrying one channel of audio. In a stereo setup, this is simply left and right but obviously in a multi-channel setup, each length of cable carries a single channel of audio. As I said, using multi-channel phono cables is for people with older amps and those that use SACD and DVD-Audio.
If you're buying new equipment including Bluray (BD) player and AV receiver, they will invariably be equipped with HDMI, so don't worry and obviously when you come to buy, check the reviews and post further questions on the forums.
d4v3pum4:
Thanks & will do.
