- Aug 10, 2019
- 2,556
- 5
- 0
I have been hoping to buy an HD/Blu Ray player and also upgrade my AV receiver for some time now and had my mind set on the Sony STR-DA1200se receiver, however since the release of the new Onkyo series, im now not so sure.
The reason for this is that i have been reading that at present HD/Blu Ray players internally decode the new HD DD/DTS audio codecs, and can only output these via HDMI and 5.1 analogue as uncompressed PCM, meaning you dont require the onkyo's on board HD audio decoders. And the only reason you would require these decoders is if the HD/Blu Ray players sent the codecs as bit stream.
My question is, if and when HD audio can be sent via bitstream from HD dvd players for the receiver to decode the signal, will the sound quality be superior to letting the player decode it, leaving a non HD receiver to proccess it via HDMI or 5.1
I really dont want to spend the extra cash on a full spec HD audio equipped receiver if a model such as the Sony 1200es etc can give just as good results via uncompressed pcm. And if this is the case will my old Denon receiver with its 5.1 inputs do the job just as well.
Has anyone any comments on this, or am i completely off track with my thoughts.
