- Aug 10, 2019
- 2,556
- 5
- 0
I would appreciate advice from members that have themselves had FM/DAB external aerials installed.
I am going to arrange to have an external aerial installed so that I can get good reception for both FM and DAB for a Denon TU- 1800DAB Tuner which is being delivered shortly.
While the Hi Fi system is in the main front room we have/will get other tuners in other rooms too. Have others found it worthwhile to get other rooms in the house connected to an external FM/DAB aerial at the same time as their main Hi Fi system?
I was thinking of also getting an aerial connection for the Kitchen and family room but also possibly in the kids bedrooms.
I was wondering if you would need separate aerials for each room - in otherwords if you have many rooms using the same aerial for DAB or FM does this compromise the signal?
Any thoughts aprreciated - we are going to be in the house for years and so if I am getting this done I would like to do it as effectively as possible.
Does getting more connections add significantly to the costs? Any ideas what installation costs are likely to be?
