Harmony Remote - Guidance required
MrW
18
OK, here is the scenario:
SKY+ HD box located centrally in the house in a cupboard
TV wall mounted in Living Room, and the TV is connected to the SKY box via HDMI.
Problem: Can't use the Sky remote as no line of sight owing to box being located elsewhere
Solution 1: Sky + app for iOS. Not ideal, as you cannot get Sky Guide or any of the settings to display on the TV, and at best trying to find something to watch can be 'painful' using an iPad
So:
Solution 2: a Harmony Remote?
I know nothing of these devices, but could it be used to mimic the Sky remote?
Having looked at Logitech's website I am none the wiser, so I'm looking for real world experience!
In essence, does the Harmony 'hub' live in the cupboard, and link to the Sky box via IR, and then the remote communicates to the hub?
Thanks in anticipation....
MrW
18
Thanks Robin
But... does it do what I want it to?
Will it allow me to have a fully functioning remote (ala Sky) in the room where I need it?
visionary
80
MrW said:
Thanks Robin
I think you want something more like this clicky because the Harmony (at least the one I've got) is still only IR in line-of-sight
Sounds like you need a relay to the location of your Sky box and that is what this device does. I've used a similar one from one room to another
MrW
18
Thanks @visionary
I've seen this on Harmony's webiste and 'think' it might do what I need...
http://www.logitech.com/en-gb/product/harmony-ultimate-hub?crid=60
It could live in the cupboard with everything else, use an IR extender which then allows the remote to communicate via Wi-Fi
Well... thats what I think it does!
visionary
80
From that site
"The Harmony Hub also allows you to control home theater devices located behind cabinets or walls. You don’t have to point your mobile phone or remote at your devices anymore. You don’t even have to be in the same room."
sounds like it does just what you want.
Nice find
MrW
18
I've emailed Logitech to try and understand exactly what this does
At £69.99 it sounds like an absolute bargain
Fingers crossed, and I'll report back when Logitech get back to me
MrW
18
Looks good @hammill, thanks
Just need Logitech to confirm this does what I need it to do
Otherwise back to the drawing board!
MrW
18
Update:
Logitech are proving to be as useful as the proverbial chocolate teapot...
So far all they have confirmed is that this is compatible with my TV, which I already knew!
MrW
18
Update:
I conclude that Logitech's support team are nigh on useless.
They do not know if their system will do what I want it to
I think this may have something to do with 'Geoffrey' being based outside the UK and his inability to understand English
Shame
RobinKidderminster
582
When setting up my Harmony One they were excellent. My TV would not switch on - advice by return email. My lighting was not listed on their database so they edited my settings online and all worked fine. Wonder if their recent ownership change has destryed their support? They also sent me a free battery after 2 years. Logitec.WERE great. Hopefully still are!
Series1boy
355
13
18,895
I've had 2 harmony remotes with harmony one being the remote I currently use now. It works perfectly and controls everything in my signature below. You may have to play around to add more buttons but this is easily done.
