A admin_exported New member Aug 10, 2019 2,556 5 0 Dec 8, 2011 #1 bit sad really,I can't get the old battery out of my Harmony One,any tips please(usefull ones) thanks
P Paul. Well-known member Nov 26, 2010 745 55 18,970 Dec 8, 2011 #2 It sounds like the li-ion battery has swollen, you may need to take the remote apart to get it out. Cant think of any other reason for it sticking? Dont forget, it does have a two year warrenty, how long ago did you buy it?
D Dean65 Well-known member Sep 24, 2008 1 0 18,520 Dec 8, 2011 #3 I had the same problem and the battery wouldn't stay charged for more than day. I used a biro pen top to lift the swollen battery up and out. Logitech replaced the battery within 3 days under the 2 year warranty.
A Anonymous Guest Dec 9, 2011 #4 thank you both,the battery had swelled up quite a lot,about 20 to 25 % at the thickest point. levered it up a notch with small screwdriver and used point of very sharp knife to slide it out should be ok for another 2 years
