Hard Drive upgrade -Sky HD
Mr Gaz
8
How many hours HD recordings could i expect from a 750 GB hard drive (approx )
Anyone please .
Tonya
57
Well, it's quite hard to be accurate as depending on the compression ratio used in different programs, one can't say that 1 hour of HD will take up xxGb of space, so I can offer the following wisdom :
Installing a 750Gb drive will leave you with 610Gb storage (750Gb minus AnyTime reserved space).
The last drive I installed was a 500Gb job and that was tested to reveal 200 hours of SD or a tad under 75 hours of HD broadcasts.
Mr Gaz
8
Thanks Tonya
Recently received box from ebay with 750 gb upgrade completed - ive nearly filled this with 40hrs hd content ( i expected 100hrs +)
Ive been assured the hard drive is 750gb as sold.
Does the sky software automatically recognise the increased capacity and adjust the percentage needed to record a given program .
example - 4 percent on 300gb standard box might read 1 percent on 750gb box
As you can see i don"t understand the workings of hard drives think i may have been sold a 300gb box ha!
RobinKidderminster
582
Sound advise on best HDD and upgrade info would be an interesting thread. I'm not sure if I can take the upgrade path. Need a kind hand i think.
Cheers all
daveh75
826
231
19,270
RobinKidderminster:
Cheers all
Have a look HERE, tells you just about everything you need to know on upgrading the HDD.
