I dont use my sub all that often due to neighbours but turned it on for a blast this morning as they are all away (Yay holidays).
Appears its broken for a 2nd time (I have owned it about a year and 2 days so warranty is probably kaputnik) - essentially the lights dont work on the EQ buttons. Rear light goes red when turned on and green when receiving a signal. But it does one of 2 things on the top 2 lights:
Either both lights come on faintly and if you press either one of the EQ buttons then one of the lights glows brightly while the eq button is pushed and then returns to the faint blue when you take your finger off.
OR
Neither light comes on and then when you press either one the EQ2 light comes on strong and then goes off again as you as you release either button.
Sub appears to function as I can hear it and responds to the gain control
Im sure I had the same thing 6 mths ago - MA were great, sent me a replacement eq section (tricky to change though).
As i hardly use the thing i am frustrated it has let go again after so few hrs use.
Is this common? Im gonna call MA when everyone returns to work
y
OR
y
