Hi guys,
I need some advice. I have a grounding issue, or believe it to be. I recently purchased a Project Genie 3, cheap as chips Turntable. It's connected via a Cambridge Audio 640P Phono, to my Arcam Solo Mini. I also have a Sonos and a Arcam rDac for what it's worth. Cables are all Chord Chrimsonplus. The earth/ground wire is the original taken from the supplied cable with the unit and obviously this is connected to the 640P. Speaks are by the QUAD L2's which I've had for about 8 years, recently purchased EB2's waiting on them. This is my second hifi - previously, in wealthier days had a Primare, Stax, Rocksan Radius, leema, Spendor A5 setup. Now space and money only allows for the Arcam etc. I'm saying this not to impress, as I know there are better out there, but more so to point that I am not new to this.
The issue is a loud crackle and hum, constantly when I use the turn table. It was fine initially, but recently developed this hum/crackle. Put it this way, I am unable to listen to LP's as a result. OK, yes it's not the best turntable in the world, but wanted something basic, but you do expect it to not have an issue like that. I've checked all I can, even used a different phono stage, and cables. Still results in the same issue. Double checked all the connections and tried a different connection into the Arcam. Further from that, I've tried moving the phono box away from all the others, just to see if that was a result of the issue. I am at a loss. Sadly, Needles & Spins are not replying to my emails and never pick up the phone. Despite me saying that I would pay more for a better turntable if they took this one back.
Any thoughts on what else it could be?
Stu
Stu
