Wasim:Does high end user of hi fi components uses graphic equalizer? the reason i ask, I am using a 10 band yamaha graphic equalizer. it is connected to a yamaha integrated amp. i find a distinct clarity when i listen music. But when i listen music directly from the amp bypassing the equalizer, the sound clarity goes off. Can a good CD player and a good amp + pre amp give a good sound clarity?
Pretty much as The Record Spot mentioned: Worth considering that even if you get the tonal balance spot on with modern amps you'll find that you gain a little versatility with the equaliser, especially on old mono 7" singles (or any recording that's fairly poor), but may lose out on a natural presentation. Either way, it's about striking the right balance.
Just as an experiment, try to disconnect the equaliser altogether and see whether that makes any difference. Probably won't, but I'll be interested to find out.
