johnnyjazz:When you go to a hi-fi convention do they have chopping boards under stands, no, do they have tennis balls under, no, go to your hi-fi shop, do they use them, no, i think that tells you something.
What tells you more is if you get there early enough and hear them all bitching about how bad their tiny little room sounds! There was a lot of unhappy demoers at Bristol this year, I didn't notice anything like the number of complaints last year.
It's a bit of a generalisation but hotels are usually pretty solidly built, that's what you need, a firm base under the speaker, if your floor provides you with that there's no problem. I've got a solid concrete floor in the living room, I just spike straight through the carpet and that's it, nothing else needed.
Am i the only one who is satisfied enough to just press play ,sit down and listen?
No but you should hear my dining room, springy floorboards over a cellar, it's like a giant sounding box on a guitar, huge bass boost, I'll have to do something in there if we swap rooms, which the other half is threatening me with.
