Gold plated HDMI cables 1.5 metre £5
  • Start date
chebby
1,251
24
19,195
What is it's official HDMI rating? High Speed? What?
Since 2012 there should be one of these on ads and packaging ...
If not then you don't really know if it's up to at least the minimum HDMI technical standards. (Most 'frou-frou' or boutique cables aren't.)
Gold plating is only necessary in places like salt mines or trawlers.
Deleted member 2457
I think it's just 1.3 HDMI, probably best to avoid then unless it will do the job.
daveh75
727
138
19,070
No such thing (its only used in the marketing of cable sellers).
As chebby mentions they should be rated as either 'Standard' or 'High Speed'
Still from £69 to a fiver it's got to be a bargain...... hasn't it?? :)
Certainly sounds very frou-frou to me.
daveh75
727
138
19,070
I recently got 3 good quality 1.5m 'High Speed' certified cables for £4.50 off Amazon
Deleted member 2457
I am not sure then, could give them a ring to see or just buy elsewhere like Dave.
Deleted member 2457
Vladimir
220
Regardless of gold plating, HDMI will not give color accuracy like 24+1 DVI-D will. Although color accuracy doesn't matter much on a TV I reckon.
